ive decided to sell my GTR and everything that goes with it after being so close to completion im just over it and have other priorities right now.
OS GIKEN RB30 SHORT BLOCK $17k BRAND NEW NEVER USED
full motec m800 setup with motec SLD dash, SLN, CDI ignition, everything imaginable 17k (cost 25)
full race spec jun head NEW NEVER USED, 11k (cost 13)
hypertune intake w/90mm plenum and billet fuel rail with water breather setup NEAR NEW 4k
greddy radiator NEAR NEW 500
greddy 150mm intercooler NEAR NEW 1500
1200hp triple pump surge fuel setup and all lines USED FOR 1 START UP 5k
trust single hi mount manifold and wastegate AS NEW used for under 1000km 2k
19x10 racing hart rs721 with hankook 265/30/19s 95% tread 3k
everything is sitting at a workshop in sydney and can be inspected upon prior arrangement with myself and i will arrange it with the shop (apart from the car and m
also selling the r32 gtr as a rolling shell for anyone who may be interested $12k ready to drop an engine and loom into
- custom dark green, has all glass/panels/lights intact and good condition and complied
- tein super streets
-kts hicas lock and front upper arms and traction rods
- cusco castor rods and rear camber arms
- all brand new whiteline bushes and swaybars were fitted
- r33 gtr brembos with new DBA rotors and FERODO DS2500 pads
these were all fitted a few years ago, but the car has been off the road and when it was on the road, i had only done a few thousand km MAX highway and some street driving.
ill start gathering the pics tonight and over the weekend but if your keen most of it speaks for itself msg me and well go from there.
everything is located in sydney
thanks!!
  • Replies 43
pms replied, had a few pms about the head for specs, its a stage 2R head 280deg cams high lift double springs, retainers, nitto guides and valves and everything is brand new, the head was brought brand new from nissan and its assembled ready to go!!
thanks
pic of car and wheels
pic of engine bay where the intake side can be seen and the radiator,
fuel setup in boot, there is also a fuel filter and the lines that run under the car all the way to the front to be included.
ll be going to the workshop tomoro to take pics of the head and as much as i possibly can!!
Edited by SRB
I know how you feel big fella. I am almost at the same point as you, seems all I am doing is emptying my pockets and going nowhere. PM sent anyway!
some pics of the head, - the cams and springs have not been installed yet, although they will be for the prospective owner.
jun stage 2r hi lift cam kit
race porting and all new stems, collets etc etc
the MOTEC stuff consists of
- M800 ECU WITH ADVANCED FUNCTIONS
- SDL BACKLIT DASH AND CONNECTOR
- SDL 8MB LOGGING
- SKM KNOCK SENSOR
- SKM KNOCK SENSOR LOOM
- SINGLE WIDEBAND LAMBDA UPGRADE
- SLM SHIFT LIGHT MODULE
- CDI 8 IGNITION SETUP
- FULL CUSTOM HARNESS AND RE WIRE TO SUIT R32 GTR
Edited by SRB
motec sdl and logging SOLD all the other stuff still remains..
alot of interest in the head, block and intake and intercooler but nothing 100% yet...
throw me an offer u never know :thanks:
now seperating motec if need be
m800 ecu and loom w/ wideband lambda and advanced functions - $10k (wiring alone cost $8500 full mil-spec)
knock sensor and loom $1500
cdi 8 ignition $1700
these have literally been used for one dyno run
or 12k everything.
would you seperate the coolant breather tank? im assuming its hypertune as well?
hey no sorry its going with the plenum, and yes its from hypertune
intercooler n radiator is to fit which car?
r32 GTR
hypertune intake w/breather setup. intercooler with pining SOLD pending $.
ive decided to keep my motec loom for a rainy day.
the racing radiator is all alloy, 2 core, wide tube and 48mm thick
motec m800 with advanced functions - $3500
motec skm knock sensor and loom $1600
motec cdi 8 ignition $1800
Edited by SRB
Got pics of the motec stuff expecially the loom? Just wanna see how it was made up etc!
its coming out next week ill get some then
got gtr cank and rods
sure do 17k read the first post :)
MOTEC M800 AND SKM SOLD
INTAKE AND INTERCOOLER SOLD
WHEELS SOLD
MANIFOLD AND GATE SOLD
HEAD MAYBE SOLD.... WILL KNOW THURSDAY
OS GIKEN RB30 SHORT BLOCK BRAND NEW NEVER USED PRICE DROP 16K
1200hp triple pump surge fuel setup and all lines USED FOR 1 START UP 4k PRICE DROP
MOTEC ENGINE HARNESS AND CDI-8 8K
Edited by SRB
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
