Ok guys need a reliable auto electrician to come and have a look at my R33 as i think i might have damaged some electric parts when trying to jump start the car yesterday. I put the cables the wrong way (i know stupid, but hey shit happens) and had some smoke coming from inside the car dashboard. The car does not start at all, it will not even crank, all other electronics work in the car if the key is put in ignition.
So yes anyone can recommend an electrician that will not charge an arm and a leg that could come to my place and have a look at it.
Edited by aky
https://www.sau.com.au/forums/topic/370475-auto-electrician/
Checked the fuses in the boot, they look to be fine. I was thinking of maybe taking the fuses to supercheap and getting a new battery, then replace them all and see how it goes. But would still need an auto electrician in case that does not work.
Went to chk the fuses under the dashboard 2nit, thought to my self lets see if it turns on, surprise surprise it turned on and i took it for a little drive everything looked fine. Parked the car then tried to start it again about 30min later and it will not start, but it at least it makes clicking sounds now. So now i am thinking that it might be the battery that is dead, so will get a new battery tomorrow and will see what happens.
Bought a new battery, put in and it started without any issues. Took it for a drive all good, started the car after 30 min again and its still starting without any problems. So it looks like the battery was the problem after all, the other battery was all watery when i took it out so must have damaged it when trying to jump start it. So relived thought i might have done some serious damage to my car.
  • 4 weeks later...
Nerds lol
I had smoke come from my blinker switch today... Can't be good ay lol
Your relay/blinker might be on its way out. Smoke is never good. What is it? Unless its a fuse melting(which is very unlikely as they designed to blow, unless you put a higher rated 40a fuse in a 5a slot) it is most likely the wire casing melting. This isn't good. One second is nothing, but 3 - 5 seconds is enough to get rid of the plastic and leave bare wire exposed which can cause havoc. My mates ford laser smoked for about 3 seconds, he used the wrong fuse which didn't blow and allowed too much current through. The end result was a bundle of wire with minimal shielding literally melted together. He traded the car in the next day.
I'm pretty handy with electronics, if anyone needs help, I'm near Parramatta and can see what I can do. Ive fixed all issues both electrical and mechanical in all my cars and helped my brother rig up two of his cars.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
