^^^ Nice! Did you do the angel eyes yourself? I am keen on doing it, but am still a bit apprehensive.
Yes did myself, 5000K ССFL. Baked them twice because first time left ballasts inside the headlamps and because of heat a ballast was f$cked up. Now both are out of headlamps.
Sweet. Did you use a website or videos to show you how to do it? Any tips or rticks? Where did you buy the CCFL kits? So many questions ....
I am also considering putting a pair in each rear light to run full time to give me the full hotplates look :)
I'd recommend this kit. http://cgi.ebay.com/ebaymotors/2003-04-Infiniti-G35-Sedan-Headlight-hid-HALO-Demon-Eye-/360123300970?pt=Motors_Car_Truck_Parts_Accessories&hash=item53d9057c6a
You can use a heat gun instead oven it just takes more time but it is safer. What you will have to do is take headlamp off, ballast and there are 3 little screws on the back side of each headlamp.
They look so nice, cobey we may have to talk about you lights lol, i have some angle eyes to install in my ken style front bar once its on should look good, im gona look into the polish but i think that its 90% on the inside of the light, i think they did not seal it properly after compliance when they take out the stock lights and swap the over for legal ones here.
If you follow my guide it will cost you $50 for the kit from memory (most of that is in shipping, actual halos are like $14 for a pair x2)
You will need to know the size of the halos first as if you have a sedan then its different or if you have a 06+ coupe then its different than mine..
http://www.skylinesaustralia.com/forums/topic/349829-g35-coupe-halos-diy-guide/page__p__5621678__hl__halos__fromsearch__1#entry5621678
This is the before and after of when I did my headlights fyi
Nice and shiney there, Andrew. :thumbsup: Is that "Nismo" sticker inside or outside the headlights?
For me, I drive my V35 mostly evenings on weekends when it's getting dark. But, I resist myself from turning the main headlights on until it's really necessary and instead drive with my parker lights on to reduce the chances of clouding up the inside of the headlights faster. I don't know if that works though. :P
It's on the outside mate ....
http://cgi.ebay.com/ebaymotors/Nismo-Nissan-wheel-Decal-Sticker-_W0QQcmdZViewItemQQhashZitem2eb5f36b6bQQitemZ200621124459QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
