LOCATION = EASTERN CREEK WET PAN AND PEANUT TRACK
TIME TABLE
5:00PM GATES OPEN
5:30PM SCRUTINEERING
5:30PM DRIVER SIGN ON
6:15PM DRIVER BRIEFING
6:30PM START TRACK ACTIVITY
10:30PM END TRACK ACTIVITY
SPECTATOR
everybody is welcome to spectate at our events entry is FREE
we have an associate membership package available for spectators
costs $50 you get t-shirt, sticker, membership card and a free drink at all our events
you can apply for this on the day
SCRUTINEERING
your car will need to pass scrutineering
brakes, brake lights, seatbelts/harnesses, windscreen wipers and headights all need to work properly
drivers seat must be secured properly all wheel nuts must be present
you will need a secondary bonnet restraint if you dont have one just bring a short rope & the
scrutineer will assist you installing it
DRIVER/TRAINEE
to drive you will need appropriate clothing (non flamable)
your clothes must cover you from neck to wrists to ankles
closed shoes must be worn
and only helmets with the AS1698 sticker affixed can be used
COST FOR DRIVERS
$80 per driver
driver must nominate wet pan or peanut there will be no switching between the two
PASSENGERS/TRAINEES
$80
same clothing requirements as a driver, you can ride in any car of your choice
CAMS RELATED and COST
we can issue you with a cams license on the day
$57 yearly L2NS you will need to purchase club membership
$45 days L2NS no need to purchase club membership
please take note that to be able to hold a yearly cams license you need need to be a member of a cams affiliated car club ,for driftmob membership information read on
DRIFTMOB MEMBERSHIP
if you want to become a member you can apply on the day
$50 for an associate membership incudes a t-shirt and membership card
$120 for a full membership includes long sleeve shirt, membership card and stickers
$177 for a full membership includes long sleeve shirt, membership card, stickers and yearly L2NS
$80 for full membership yearly renewal
for more information visit http://www.driftmob.com.au
HOW TO PAY
entrants can pay on the day but we recommend prepaying to secure a spot
at this stage we can accept cash and eftpos if you want to pay on the day
we also accept over the phone credit card payment
PREPAY
deposit total amount and bring your reciept with you on the day
no prepayments after MONDAY 19 SEPTEMBER
ACCOUNT NAME = DRIFTMOB INC
ACCOUNT NUMBER =259589
BSB =032372
BANK =WESTPAC
just a quick run down for the day,
strictly no refunds what so ever
passengers/trainees are permitted at this event
we are track time orientated this means we will not stop for lunch
for more information on DRIFTMOB CAR CLUB visit http://www.driftmob.com.au
cheers.
the driftmob crew..
  • 1 month later...
  • 5 weeks later...
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
