Hey fellas,
having a problem with a r33 96 v spec gtr, two workshops have looked into this and given up,
problems is or was at first that whenever we broke traction like even just a little bit on a gravel driveway or in the wet the 4wd and a-lsd lights would come on???? the car seemed to be fine still in 4wd mode and all???
to complicate things furtrher now the lights dont come on when we brake traction so we have difficulty showing anyone, they now generally come on after the car has been driven reasonably and then after its left running for a minute sitting still!!!!! they dont go off again until the car is turned off and re started!!!!
****IN givin me the shits!!!
we are running a microtech ecu.....
since the car still mechanically seems to be working properly, id say it is a electronic problem
check the fuses, then get the attessa pro computer checked out aswell (maybe swap with one to c if its the problem)
ok,
no the car has never been in an accidednt and no mechanics can find any serious damage.
the car has about 30 k on the clock , but being an import??? but the car is in good nick.
the lights are now coming on after the car has been driven and if its then left running and stationary, like at the traffic lights or something. the lights stay on until the car is switched off and started again.
so you have seen this before then Lal??? what did people do to fix it???
Im unsure if its the same in the R33's, but in the R32 the ATTESSA control box is in the boot (open the boot then look on the roof of the boot and theres a few boxes). Theres a silver one with a LED on the bottom of it. This is the control box, if theres an error with attessa it will flash a fault code (when the lights come on, pull over, dont turn the car off and check what its flashing).
Have you checked the transfer case fluid levels and the attessa fluid levels? Mine was running low and this caused havoc on my car... but once again its a 32 not 33.
i fixed it myself, got some help at sendai drags when i was back there...
in the boot there are fuses all over the place..
on the MIDDLE SET OF ROWS the SECOND fuse going DOWN pull that out.. then try to turn your car on.. it wont turn on . then put the fuse back on then turn it on.. and see how you go from there. this usualy fixes it..
Why not just AXE the ATTESSA and buy a replacement bar from me, then pull the globes from the annoying warning lights.
No ATTESSA, no problem...works for me on the track.
dude i think that's hicas u mean...the whole reason u buy a GTR is because of ATTESSA
i''ll probably check the fluid levels and the fuses 1st. not sure how to get the car to diagnose attessa problem codes but if you had a mechanic with a Nissan consult near you that'd help.
might be the clutch pack that activates the attessa is worn or spoilt or something.
get on the internet to find out...i found out how to get the hicas to flash problem codes from the net...i'm sure melb has some good GTR mechanics out there like the guy who used to tune the GTRs that ran in Bathurst...but he's pricey.
geoff...yea i always find i have to correct and re-correct the car on a hard exit so i think a hicas lock would be good
LAL....
i'm looking at the fuses and i'm seeing a centre row of marked fuses, the third fuse down this row says 4wd-lsd which are the lights that are coming on so i'm gussing thhat this is the fuse you are talking about???? the 1st fuse says MAIN so i'm guessing its not that, the second one down says BLOWER so i'm guessing you mean the 3rd one down called 4wd-lsd?? i'll try this one, there is also a big blue fuse sitting by itself i dont what this does????
RB26dett i dont know what your talking about none of the computers in the back of my car have any LED on them and its a ATTESSA problem not a hicus problem, but thanks for the input, i'm not being sarcastic maybe your thinking of an r32???
cheers fellas,
On that note, im now starting to experiance problems with my attessa system. Its a 1992 R32 GTR (non v-spec). It still drives fine, not flashing any fault codes, but when im driving normally, its putting torque to the front wheels (goes upto 25) when it never used to (unless I was hammering it, it would stay rwd). Cruising along in 5th gear, even when I tap the throttle it goes up a little bit.
Any ideas?
tribex, when the 4wd light comes on does your car go into rwd mode only? From your original post, it sounds like it stays in 4wd mode but the light comes on. Usually light coming on means 4wd is disengaged...if this is the cash...try bleeding the system...air in the system causes this....hope this helps
No expert here.. so dont bag me if this sounds silly...
Do you have stocks wheels on your car? Are the Tyres exactly the same size allround?
I had a similar problem with my gtr when I fitted 19's to it.. problem was the rims were different, 275's at the back & 245's at the front, and the ATTESSA was sensing this as a loss of traction. I was also told that in the case you have major uneven tyre tread wear, the ATTESSA will sense this as loss of traction & the 4WD will light up.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
