  • Replies 94
Come say hello where?
Good to see another new face has joined the ranks... Come along to one of the meets...
Also,I should let you know that in the aim of matching faces to names etc Im going to have to ask you to post a pic of yourself...
You're a ****ing wanker mate. There's plenty of porn on the net for you already and I'm sure you're always down for schoolies.
lol!!
Thanks for your input... Never been to schoolies and yes there is alot of porn on the net.
Nice to meet you.
Im glad you thought I was special enough to have to 'keyboard warrior' it up for me... Id be lying if I said I wasnt turned on right now...
lol!!
Nice to meet you.
aah, Smoothline, you're funny. let's see, one post from anna, and how many from the rest of us?
"yo, she bitch, lets go." ????? I mean, WTF?
:wavey: Hello Anna32
nice to have yet another member amongst our happy little family
And "Abo" Bob whoever you are???
WTF is your problem?
Smooth has been on these forums for a long time now and is one of the nicest guys you will ever meet.
You might just want to stick to the NSW forums so you don't get offended by having no sense of humour
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
