Dba Rotor & Intima Sr Pad Group Buy Excellent Prices!
DBA & IMTIMA PAD GB 20/7/11 till 25/8/11 (or till ten spots filled)
Ok guys this is it DBA and intima pad group buy is up you can buy just the pad's or just the rotors if you want them both combine the price for the pad and the rotors togeather off the price list i have put up if you want them for a different model or car etc PM and post and i will get quote's for you be patient though :) all prices include delivery to your door!!!!
Other rotors 5000 series standard and standard intima pads avalible at request post and PM and be patient please
Supplier is Carbling and is a local business owner looking out for us guys http://www.carbling.com.au/
DBA rotor information
Motorsport and premium street performance
6X6 WIPER-SLOT Vehicle
Body Style Driving
Conditions Braking
Style 4000_wiper.jpg Sedans
Wagons
Coupes
Pickups
Convertibles
Minivans/Vans
4WD'sStreet Driving
City Traffic Driving
Country Driving
Off-Road
Motorsport
RallyNormal-Hard
Heavy Load/Towing
Racing features_4000.jpgDBA's mid-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
The unique 6x6 Wiper Slot is designed to efficiently clear the gases, dust and debris, resulting in a cleaner disc surface for better braking while maintaining maximum friction.
4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%
Designed for the performance street and motorsport enthusiast
Premium quality braking for normal street use
XS Vehicle
Body Style Driving
Conditions Braking
Style 4000_XS.jpg Sedans
Wagons
Coupes
Pickups
Convertibles
Minivans/Vans
4WD'sStreet Driving
Country DrivingNormal
Normal-Hardfeatures_4000.jpg4000_web_XS_comp.jpg DBA's mid-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
The unique 'XS' pattern is a premium (advanced) cross-drilled and slotted pattern, providing improved braking performance for street use only.
Intima SR-6300 Series Brake Pad
Application:
Performance Street, Circuit Race & Drift Track Use (Low Dust & Hi Temp 700°c)
Description:
Intima's range of SR-6300 brake pads provide stable braking through the entire temperature range and have superior fade resistance. These pads are for the driver who wants confident braking on the street and on the track. The SR-6300 brake pad provides this confidence by having excellent braking capability up to 700°c. These pads also have a very low dust output and a 100% non Asbestos organic (NAO) formula.
Specifications:
Heat Range:
Effective Braking 50°c - 700°c
Average µ:
0.4~0.5
AMECA CERT CDGE CODE: TBT SR63T GG
100% NAO Formula
Recommended for use with slotted rotors
Pricing list (includes delivery to your door!!)
word doc.docx
ok guys fill and place orders away :)
1.
2.
3.
4.
5.
6.
7.
8.
9.
10......................................
Edited by BLITZ-26
You might want to talk to GSL Rallysport.
For my M35 they've quoted me $410 for DBA 4000 slotted fronts (pair) as their normal price, so assuming your non-Brembo discs would be about the same, I'd say if the pricing was sharper for the group buy you might get a better uptake?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
