  • Replies 112
1. Boz+1
2. Boiracer
3. Isola
4. Arebees13
5. Kiwibob
6. Sexy Dave
7. Smity42
8. Smity42's +1
9. olloSKYLINEollo
10. SPR34
11. Fineline
12. Sneakey pete
13. Jazzahks
14. TommyR34 +1
15. Mumslayer
16. Grae35 +1
17. Cobbadan
18. SinistaGTR +1
19. SinistaGTR's +1
20.SinistaGTR's +2
21. Bunta +1
22. Bunta's +1
23. Brandon
I'm in screw this flu I'll be over it by sunday.
I wish i was over it :(
So everything all good for sunday? no sudden changes?
AM looking forward to it. I have a new gear knob so im sure that will make my beast faster :P
I am going commando to further reduce the weight of the car
Might have a shave in the morning too
Sorry if this has been previously covered, but are helmet and long sleeves needed, or as it is happy laps, as you are is ok?
Well last time we came as you were. I dont think anything has changed. It is meant to be FUN not timed lol.
Hmm shaving might be a good thing for me as well
Hey all,
Sorry I havent been here to answer questions or update the list, ive been away without computer access for t wo weeks *Sigh*
Anyway, list is now updated
1. Fineline
2. Boiracer
3. Boz
4. Arebees13
5. Kiwibob
6. Sexy Dave
7. Smity42
8. Smity42's +1
9. PWND
10. SPR34 +2
11. Fineline
12. Sneakey pete
13. Jazzahks
14. B-boi 34+1
15. Mumslayer
16. Grae35 +1
17. Cobbadan
18. SinistaGTR
19. SinistaGTR's +1
20. SinistaGTR's +2
21. SPR34 +2
22. Skyline_steve +1
23. Skylinestyle101
24. Randomhero83 +1
25. v8skylineman+3
26. Mrbenno
27. Sabbai +1
28. R-PWR
29. Joe_89 +2
If its no helmet ill come my one is still in Melbourne so 330 meet at aspley ? So I take it this is just casually driving around Lakeside and more a social event :)
Yea no helmets mate, 3:30 is the departure time so get there before then :thumbsup:
its about the track experience and to get some time on there, its a not a race. Just give each other space and be polite. Obviously if people are worried about the rain then maybe this would do you the world of good to enhance your driving skills. Remember its a social meet not an attempt at the land speed record around lakeside.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
