hi guys there is a cruse i am trying to organize tonight may not be a huge turnout due to the late notice
Where: Palm Beach
When: meet around 7:30 pm for a 8:00 pm departure if you are going to run late please post up here as i will be checking it but we wont be waiting around long
Weather: If the weather stays good then we will go but if it starts bucketing down i may cancel it (palm beach is a great place to take some photo's and hang out ) but if it rains there is no point
check back if i don't chance it by 6pm then its on !
Route: i will explain before we leave the meet point the route it is quite straight forward (IF YOU ARE CROSSING BACK OVER THE BRIDGE PLEASE BRING YOUR E tag alternative you can go Anzac bridge to avoid the toll)
MEET: at foreshore road Boat ramp as you come out of the airport tunnel and keep to the left take the foreshore road exit and make a right hand turn at the set of lights half way down i will post up a map to get there !
http://www.whereis.c...=D81B250BCC5552
IF anyone has any problems getting to the meet point feel free to call me on 0403569075 (JOHN)
IF ive missed anything please ask will be checking back often
https://www.sau.com.au/forums/topic/371811-cruse-tonight-230711-palm-beach/
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
