Hi, I have some parts for C34 Stagea which I no longer require.
Located in Boronia, Melbourne but I'm happy to freight at your expense.
0419-010-757
Cheers, Chris.
1. 3" Cat Back Exhaust - $550
This exhaust was made by Rowville Exhausts in mild steel with a straight through stainless steel Magnaflow rear muffler. It tucks up closely to the body and is relatively quiet. It will pass EPA (<90dB)
2. 16 x 7 Series 2 Nissan Stagea Wheels & Tyres - $450
These have just been painted in gloss black by Bayswater Panels. Tyres are 205 65 16 and are in road worthy condition.
3. Set of 4 5-Stud 25mm Bolt on Spacers - $150
4. Complete Set Front & Rear HPX Brake Pads - $100
These are for the earlier Series 1 Stagea with the slightly smaller brakes as these pads did not fit my 99 model Series 2.
5. Intercooler Piping suit RB25DET R33 GTS-T, R34 GTT & C34 Stagea (Return Flow) - $100
6. Front & Rear Spings - $50
7. Front & Rear Sway Bars - $50
8. Front Indicators - $20
9. Dash Mat - $20
25mm bolt on spacers SOLD.
keen for the rear springs, are ya willing to seperate??
PM sent
hey rob i've replied to your PM
Postage for the dashmat to 2619?
i'm doing the dash mat for $30 delivered but you're now the 3rd person in line to have enquired..
just a heads up the dash mat is not a rolls royce of dash mats, it looks like a SAU group buy custom made kinda thing but some strips of velco and you'd be right.
3. BOLT ON SPACERS >> SOLD
4. PADS >> SOLD
5. INTERCOOLER PIPNIG >> SOLD
8. FRONT INDICATORS >> SOLD
9. DASH MAT >> SOLD
G'day,
I've got 2 questions
1 Have you still got the wheels?
2 Being stock, will they go straight onto a RS V?
I'm only asking because after reading some posts about wheel offsets depending on the model, I'm getting confused about what would fit on my car, being a rwd auto.
Cheers
  • 3 weeks later...
G'day,
Cheers
hey mate sorry for late reply i've been overseas..
yes i have the wheels, yes they will fit your rs-v.
cheers, chris.
Hey there, you don't happen to have that plastic hook thing attached to a bit of string in the boot where u lift up the spare tire panel? =P
nah i'm not wrecking a stagea i just have few bits and pieces - only whats listed.. sorry mate
Yeah still interested in the wheels. I've sent you a pm.
Cheers
hey mate yeh sent u pm, thanks.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
