hey guys i am going to be selling the spare motor now as i will prob never get the funds together to build it now.....
it is as i stated in the topic..... 1993 late model r32 gtr motor.. so it has the same oil pump drive as an r33.....
it has the oil and water pumps attached and is missing the loom and the ancillaries... so it is just a long motor with a complete set of rb26 engine covers... including the coil pack cover.
the engine has litterally done 70,000ks and as soon as it spun the bearing it was shut off and removed.....
i am chasing $2500 but throw me your offers i would like it to be gone...
pm me on here for details
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
