  • 1 month later...
gday there toby replied to your other thread , just wandering your passenger side rear quarter you damaged at drift supercup is that correct man ?
also after that bonnet if you still have it
also a few other bits and pieces
such as front metal reo
stock r32 gtr intercooler core
pair of passenger side front door hinges
please let me know wat you have lying around hey and will take it off ya hands
regards anthony
  • 2 months later...
  • 5 months later...
gday toby , not sure if you still use this man , but in need of that bonnet if you have for sale still bro , and if you have a stock plastic front grill that would be sweet az well man
anyways please get back to me asap
thanks for your time
anthony
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
