They changed the style a while ago Ive been told, old style had the wipper slot going to the edge of the disk where as the newer ones didnt, like mine.
Are these new ones more efficient at removing built up gasses? Whats the price difference, are these replacing the DBA 4000 or are they just another line.
Just read up on it, no more left and right hand discs, and more off gassing apparently.
Easy on the machining as they dont need to tool up for 2 different sides so they save money on manufacturing, will we see it at the shop, I doubt it.
Extra off gassing is good if its needed I suppose.
Yes, new things scare me......................
