funky you sat GAMSAT? are you studying med?
GAMSAT = graduate australian medical schools admissions test
basically 9am-5pm of breaking the nuts with freaky-ass questions and stuff
not good, but you have to get a good score if you want to study medicine or dentistry...
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-746808
yeah I know what gamsat is. Its not compulsory to med in NSW, but if you wanna do dentisty in NSW or Med in other states you have to do it. I got accepted into med, but I turned it down n did M Biomedical Engineering / B Computer Engineering instead.
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-746842
yeah got your pm about bar. have decided to go 3" exhaust before front bar so will have to wait unfortunately ;)
GAMSAT was a bitch yet again. tough stuff if you ask me. how did you find it? how is third year treating you? let me know if you want my help or any work i can give you etc.
waz.
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-754101
you can order practise tests when you register for the test (www.acer.edu.au) but otherwise no. there is a brochure with the format ofthe test etc. but its designed to test your way of thinkign and interpreting data rather than general knowledge. thus its hard to study for.
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-755719
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
