Planning to get some upgrade's soon for my r33 gtst so these are up for grabs
Pickups from Runcorn/South Brisbane or can drop them off locally or post/courier
Send any resonable offers via PM-I'll add pics soon
-Pair VGC 17x8 +38 Lenso D1R's
Both look almost new-one rim has a 2" section of very light rash
$400 ono
-Pair of WORK Meister 17x8 +40 SR2's
One rim has a bit of gutter rash on outside edge-no biggie-other rim doesn't
Bridgestone Potenza REO5OA 225/45/17 50% tyres
On my r33 atm-rims sit inside rear stock gaurds
$450 ono
-"Black Racing" Pro N1 Japanese lightweight alloy rims-thin six spoke-dark bronze
Rare rim-discontinued years ago
Original retail price was $350+ [AUS] for each rim
Two 17"x8" offset is +38... one rim has a section of light gutter rash-easy to fix
Two 17"x9" offset is +38...one rim has two very small scrapes/not really even rash
Front tyre's 235/45/17 Federal Super Steel 595's-evenly worn 70%+ tread
Back tyre's 255/40/17 Nangkang's-evenly worn 90% plus tread
$900 ono
-ZIMA 17x8 +40 silver 5 spoke wheels VGC
No damage or gutter rash-only a few light scuffs/scratches on paint
missing one centre cap-fitted nicely on my '99 Stagea/r34 wagon
two yokohama tyres are about 50%
other random tyres are about 30-40%
all are 225/50/17
$600 ono
-Set of stock silver 16X6.5 +40 s15/200sx Silvia wheels
Two rims have minor gutter rash-one rim has rash along 1/5 of edge of rim-other rim has a very small bit of rash
All "Sailun Altrezzo" 205/55/16 tyres are evenly worn
Two are 90% & two are 80%
5 stud/5x114.3
Will fit r32/r33/r34/s14/200sx/some Commodores or most hubs with a PCD of 5x114.3
$450 ono
-Five stud/5x114.3 yellow space saver wheel
Will fit r32/r33/r34/s14/s15/200xs/some commodores or anything with PCD of 5x114.3
$60
ono
Also have these to sell or trade for silver ones in same size/offset...
-Pair of near new 17x10 +15 white Lenso D1R rims with 90mm dish
One rim a small section of light gutter rash-other rim is allgood
Both tyres are evenly worn 40% 235/45/17
Can fit inside r33 gtst rear stock gaurds with adjustable camber arms
$450 ono
post-59075-0-82207400-1312455377_thumb.jpg post-59075-0-31790900-1312455416_thumb.jpg post-59075-0-62005500-1312455669_thumb.jpg
S15 stockies & "Black Racing" wheels are gone
I'll only trade +/- cash for these parts for series 1 r33 gtst/rb25det...
Garret gt35r or gt3076r new or low K turbo
Apexi Power FC
r33 GTR or Boshe 044 fuel pump
Aftermarket fuel rail
z32/300zx air flow meter
Pics on request-they wont upload atm
I'll also trade plus $ my way for a series 1 r33 gtst aftermarket radiator & RB25det oil cooler kit
Also have near new 18x8.5 +30 Lenso D1R rims
Silver with 60mm chrome dish
$450 ono
Can supply 50% Bridgestone Potenza RE050a 225/45/18 tyres for extra cash-fairly evenly worn
Also have these...
3xRAYS Gram Light's T57RG 17x8+43
Two rims are near new/no gutter rash or damage at all-fitted with 60% 215/45/17 Nankang tyres-both a bit camber worn
Other rim rim is allgood except for a bit of light gutter rash
$470 ono
post-59075-0-95756300-1315708463_thumb.jpg post-59075-0-98249900-1315708506_thumb.jpg
post-59075-0-04994200-1315708488_thumb.jpg post-59075-0-71678300-1315708496_thumb.jpg
Four 225/45/17 Bridgestone Potenza RE050a skid tyres
All 40-50% tread-all a bit camber worn so probably not legal
$40 each ono
One 235/45/17 Alpha "Accelera"
About 50% bit camber worn-not legal
$30 ono
Still had the standard camber settings-rims stuck out too much so i sold them
All sold except for...
.................Starting a new thread-mods pls delete this one
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
