Hey guys.
Stripping my 97 series 2 r33.
all exterior parts
headlights R/L (with Hid 6k) - $200 each
Doors R/L come with windows - $200 each
all interior parts
front seats - $150
rear seats - $100 (has 2 ciggie burns)
seat belts - $100 for front and back
carpet - $50
glove box - $30
centre console - $50
dash board - $150 (105XXX)
Gear knob - $30
______________________________________________________________________________
Engine/axel/control arms/diff/disc breaks/ the whole remaining car |
Engines and the rest of the car are in good condition, no damages. |
Everything you see in the engine picture is what you get + the whole car, the wheels on it etc |
$1200 guys |
______________________________________________________________________________ |
https://www.sau.com.au/forums/topic/373135-1997-r33-gts/
  • 3 weeks later...
  • 3 weeks later...
Engine/axel/control arms/diff/disc breaks/ the whole remaining car (R+L front fenders)
Engines(105XXXKM) no damages.
GEARBOX
Handbreak
WHOLE REMAINING CAR
$800 MASSIVE PRICE DROP!!!
Your going to need to bring springs or coils to get the car moving though.
https://www.sau.com.au/forums/topic/373135-1997-r33-gts/#findComment-6009133
  • 2 months later...
hey guys
Parts still for sale
front seats - $100 each.
rear seats - 50(need a clean)
glove box - $30
Price not negotiable
https://www.sau.com.au/forums/topic/373135-1997-r33-gts/#findComment-6143424
  • 2 months later...
  • 4 weeks later...
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
