2x rb26 long engines perfect for someone who has blown one up. Come sump with diff to head cam covers but no valley covers no wires comp tested $2000 each no offers sell ur head and pay for some of it. I will pull sumps off and inspect r32 motor contact 0411672105
https://www.sau.com.au/forums/topic/373171-cheap-rb26-long-engines/
