Hey guys,
Had this gear for a while from my old setup and completely forgot about it until I was cleaning up my garage.
Item: Hypergear TR43 internal gate (roughly .64 or .68 rear housing, will check)
Condition: Excellent
Price: $350
Details:
Bought it brand new a few years ago because my factory turbo died, worked absolutely fine on my car, only reason I took it off was to go for more power.
Had it rebuilt about 9 months to a year before it was removed. Its a bush bearing with a 360 degree thrust bearing in it and from memory a hard 14psi actuator.
Water and oil cooled, uses factory lines and I still have the larger flowing oil feed bolt to go with it.
Is a good step up from factory, had a really good pull, this accompanied with some support mods will do 230kw+ easy with good response, see my dyno attached.
For an extra buyer's cost I can get it checked and put on a simulator for them if they want at eastern turbochargers in Bayswater for $100-200 from memory
post-36975-0-48256300-1312686042_thumb.jpg post-36975-0-79211400-1312686066_thumb.jpg post-36975-0-27915800-1312686132_thumb.jpg post-36975-0-89496300-1312686155_thumb.jpg post-36975-0-61565600-1312686166_thumb.jpg post-36975-0-07492200-1312686537_thumb.jpg
Item: Apexi Super Suction Pipe
Condition: Good
Price: $200
Details:
These with a pod and some silicon joiners are over $400 new on Nengun:http://www.nengun.co...it-standard-afm
This suits factory position mounted turbos, stops all those suction issues and you can still use the factory afm and plumb the factory bov into it, looks good in the engine bay.
post-36975-0-22692900-1312685960_thumb.jpg post-36975-0-80348600-1312685981_thumb.jpg post-36975-0-24983300-1312685996_thumb.jpg
Item: Boss kit for 33 GTST
Condition: Brand new
Price: $80
Details: Never got a steering wheel, so just opened it for photos, apparently its for a 33, don't know much else about it.
post-36975-0-72263800-1312685902_thumb.jpg post-36975-0-98347700-1312685930_thumb.jpg
My number is 0419110110.
Cheers,
Adam
https://www.sau.com.au/forums/topic/373270-cheap-performance-gear/
Unfortunately not, as I am still using it.
as long as you have an aftermarket dump/front pipe (you need one to get the most of larger then factory turbos) it can easily be made to suit v-band style exhaust by an exhaust shop.
BUMP - Big time waster promised he was going to pick up the turbo last Thursday but then then apparently someone did a hit and run on his car at it was at the shop etc etc.....
Still have boss kit aswell.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
