what sort of rims do you like? 3,5 or multispoke? one piece forged or 2/3 piece dished? I'm contemplating getting a different set of wheels, so if the wheels on my car are to your liking, just throw me an offer. size is19 x 9 & 10 +25 f/r Work sc2
LOL looks like my car.
  • Replies 43
if i were you i would check out ozzietypes in liverpool for the price of some of these used rims you can get a great set of new rims and new types
they stock euro, ameri and ozzie rims....and i priced my wheels and types in the states to compare them to the price and the price in Oz was cheaper.........and my typres in he states are expensive.......
i guess you have a bit of homework to do
Wizlb, and what are the brand/model rims on your car? Very nice...
Yo best rims for a V35 are the R35 GTR rims, check this shit out
http://www.carsales....words=&__N=1216 1246 1247 1252 1282 4294963593 4294963846 4294931980 397&silo=1011&__No=15&seot=1&PriceFrom=397&__Nne=15&trecs=24&__sid=130DCB311D90
And i also found where to buy said rims
http://www.wheelsrim...-inventory.html
you will need to use a forwarding service to get them tho, the company does not post out of the USA but you post to the forwarding comapny in the US then they post it to you.
Forwarding service
https://bongous.com/
Edited by T4NK
I run a 10.5" at the rear.
Its OK as long as you dont replace your suspension with after market coilovers and run a maximum factory camber... thats what I did last week and the rims now have a 2mm gap from the shocks. The rear wheel touches the shocks (metal to metal) every hard turn or if I pull into a drive-way. Breaks my heart. I had to add 3mm spacers at the rear to stop them from destrying each other.
This "might" be the same if your wheels are too wide at the front. I dont have this problem because I am running 8.5" at the fronts.
Yeah, they definitely look great. :)
  • 3 weeks later...
hey guys n girls im still looking for rims and it seems no shops around are all that interested in selling them to me, so anyone got some that are forsale to suit my v35 with brembos? 19 or 20" thanks!
  • 3 weeks later...
i got some rims finally, ended up with 19x9 +20 at front and 19x10+10 at rear, fits sweet! verry aggressive at the rear tho looks sweet! ended up with rota grids that just came out in 19's saved me some cash aswell will possibly look at somthing bigger (20") later on but my tires where shot and these where easy!
Hi Guys n Gals,
I've recently fitted 20x10.5's front and back (ADV 5.1's), no spacers and no machining, under Bilstein fully adjustable coil-overs. Pretty aggressive at the front, lots of tyre stretch and I still need to get some upper camber control arms and likely roll out the guards. The rear sits perfectly with no rubbing just using a mild setting on the factory lower camber arms and lipping the rear guards (Chris at Centreline Suspension is truly a master at fitment, just need to arrange him to fit the fronts under).
Pics as soon as someone gets a camera that's not my phone, it struggles focusing on all black.
Cheers
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
