what sort of rims do you like? 3,5 or multispoke? one piece forged or 2/3 piece dished? I'm contemplating getting a different set of wheels, so if the wheels on my car are to your liking, just throw me an offer. size is19 x 9 & 10 +25 f/r Work sc2
LOL looks like my car.
  • Replies 43
if i were you i would check out ozzietypes in liverpool for the price of some of these used rims you can get a great set of new rims and new types
they stock euro, ameri and ozzie rims....and i priced my wheels and types in the states to compare them to the price and the price in Oz was cheaper.........and my typres in he states are expensive.......
i guess you have a bit of homework to do
Wizlb, and what are the brand/model rims on your car? Very nice...
Yo best rims for a V35 are the R35 GTR rims, check this shit out
http://www.carsales....words=&__N=1216 1246 1247 1252 1282 4294963593 4294963846 4294931980 397&silo=1011&__No=15&seot=1&PriceFrom=397&__Nne=15&trecs=24&__sid=130DCB311D90
And i also found where to buy said rims
http://www.wheelsrim...-inventory.html
you will need to use a forwarding service to get them tho, the company does not post out of the USA but you post to the forwarding comapny in the US then they post it to you.
Forwarding service
https://bongous.com/
Edited by T4NK
I run a 10.5" at the rear.
Its OK as long as you dont replace your suspension with after market coilovers and run a maximum factory camber... thats what I did last week and the rims now have a 2mm gap from the shocks. The rear wheel touches the shocks (metal to metal) every hard turn or if I pull into a drive-way. Breaks my heart. I had to add 3mm spacers at the rear to stop them from destrying each other.
This "might" be the same if your wheels are too wide at the front. I dont have this problem because I am running 8.5" at the fronts.
Yeah, they definitely look great. :)
  • 3 weeks later...
hey guys n girls im still looking for rims and it seems no shops around are all that interested in selling them to me, so anyone got some that are forsale to suit my v35 with brembos? 19 or 20" thanks!
  • 3 weeks later...
i got some rims finally, ended up with 19x9 +20 at front and 19x10+10 at rear, fits sweet! verry aggressive at the rear tho looks sweet! ended up with rota grids that just came out in 19's saved me some cash aswell will possibly look at somthing bigger (20") later on but my tires where shot and these where easy!
Hi Guys n Gals,
I've recently fitted 20x10.5's front and back (ADV 5.1's), no spacers and no machining, under Bilstein fully adjustable coil-overs. Pretty aggressive at the front, lots of tyre stretch and I still need to get some upper camber control arms and likely roll out the guards. The rear sits perfectly with no rubbing just using a mild setting on the factory lower camber arms and lipping the rear guards (Chris at Centreline Suspension is truly a master at fitment, just need to arrange him to fit the fronts under).
Pics as soon as someone gets a camera that's not my phone, it struggles focusing on all black.
Cheers
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
