Hi SAU,
Up for sale is my 1998 white Semi-Auto R34 25GT.
Here's a quick summary on the car:
- 1998 R34 25GT
- White
- Semi-Auto
- 56,870 on the ODO
- Brand new BC BR Coilovers (Have receipt to prove it (1.3K)
- Brand new Koya Drift Teks wrapped in Nitto NT05 tyres (Traveled less than 50km, also have receipt to prove it (2.3K))
- Brand new Sony front splits and rear speakers (Also have receipts to prove it $200)
- Regularly Serviced with only Fully Synthetic Oils
- Import Papers + Manual included
- Rego until March 2012
- Very clean
- Factory XENON headlights
- Side mirrors with Indicators and daytime driving lights, will also dim when driving lights are on (Factory ones included).
- Lowered (Suspension is adjustable, so you can slam it to the ground or have it as high as a 4WD)
- 3 keys, 1 with remote, 1 normal key, 1 blank yet to be cut.
- 7" DVD, GPS, iPod capable (Cable goes into center box), TV, SD, USB unit.
- Brake Rotors and brake pads have plenty of meat left, as the car has barley been driven and were changed during compliance.
The car is perfect for any P-Plater and awesome to drive, serviced every 5000KM, only Fully Synthetic used, very clean example, non smoker and accident car.
Reason for sale is I have fell in love with MKIV Supra's once again and I would really like a manual (Couldn't drive one before because of an injury).
CAR IS LOCATED IN BENDIGO, 3555, about 1:50mins from Melbourne (146KM).
For people in Melbourne interested.
You can catch the train at Southern Cross to Bendigo (About 1:50mins), get off at Kangaroo Flat Station and I can meet you there to view the car, so no car/bus/taxi necessary.
Inspections available Friday, Saturday and Sunday.
Breakdown on prices:
Stock (Stock wheels + Stock Coilovers) = 12K
BC BR Coilovers + Stock wheels = 13K
BC BR Coilovers + Drift Teks (How you see it in pictures, Stock wheels and Suspension also included) = 15K
Price IS negotiable
I have my eye on a few Supra's, so a quick sale is a good one :thumbsup:
Also willing to swap for a MKIV Supra, must be manual, <130,000KM.
Edited by Converge
Bump!
Price is negotiable, have my eye on a few cars, so a quick sale is a good one!
Bump!
Bump!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
