yeah mate ive got that far. What do u mean change the cluster? Im sure ive read somewhere that u can get cables that work with the original speedo and rb25 box. Also ive read a bit about people making theyre own up by changing the end with bits n pieces like a 32gtr one. Vl turbo one etc. Id rather not stuff around and just get 1 thats done, hook it up and b done with it.
The mod involves using the drive end from a Navara.
Yes.
I'm using an R32 GTR cable with a Navara drive (unmodified, I have 3.9:1 diff gears so the Navara cog worked out pretty close).
There are a few threads about putting 25 boxes in 32gtst's and they cover the speedo drive mod.
Nice, off the shelf solution.
Fine if you have standard diff ratios but also about 5x what it costs to do it yourself :)
  • 1 year later...
