1988 GX81 Toyota Chaser Avante factory
Nearly 130, 000kms
1G-GE 2L 6 Cylinder
Factory 5 Speed Manual
TEMS Elec Suspension - Still Works!
Soundstream TV CD/DVD
Rear Venitian - standard blinga ne
Got this car as a trade for my old car so im looking to get rid of it as i dont need it..
Is really clean car, would be perfect for a 1JZ/2JZ Conversion, Still has plastic on rear door trims
(got quoted 3000-3500 for JZX81 cut or Supra/Soarer)
Has good tyres, Fresh 3 Months Rego etc.. 5KONO OR SWAPS, Let me know :-)
https://www.sau.com.au/forums/topic/374023-sa-88-gx81-toyota-chaser/
  • 2 months later...
  • 5 weeks later...
i can get some more pics if ur serious.
an of course, is my daily atm..
No AC, needs regas. i can organise it to be gassed for new owner if need be
STILL FOR SALE/SWAP
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
