Hey guys,
I have a R33 series 2 manual gearbox for sale.
I bought it as a spare box for my R33 but I am selling it to fund my RB26/30 build
Great condition
Came out of a Halfcut with 47xxxkms
Comes with shifter
Box also come with modified Xmember to suit R32 conversion
$1500.00 FIRM
We all know these sell all day for this money and are worth it so dont low ball as I am not desperate to sell this item.
Located in Upper Mount Gravatt
Call/sms 0408605725 or PM here
https://www.sau.com.au/forums/topic/374721-bris-r33-rb25-sii-manual-gearbox/
If buyer is in Brisbane area I will take up to $500 in parts as a part trade. I am looking for Haltch twin port coils, acl race bearings to suit RB26, r33 GTR seats front and rear, R33 GTR guards in white with guard raisers, Drift wing or forged S2 RB30 bottom end to suit RB26/30 application.
wow a keyboard warrior!!! have you discovered that you were a love child of your mother and uncle yet??? The box looks like any other you twit and whatever I ask for it is whatever I ask for it. $1500 is the going rate for one so F**k off and go fondle your sister!
Hhmmm.. over-reaction much? Good luck with the sale. I thought you might appreciate the free bump (which you aren't meant to do repeatedly) and free advice on product pricing. Hopefully we get to shake hands over this one (for your sake).
Edited by simpletool
If you wanted to contact me about anything other than an equiry about buying the box then PM is the way to go. I am not asking an unreasonable amount for the box however stupid comments from people like yourself are not appreciated. I have mentioned I am not desperate to sell it for a lowball price and this is what the boxes are worth so no, I don't think my reply was harsh.
  • 6 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
