Selling my track car as need cash for renovations
1990 track only gtr big hks single turbo setup
Hks manifold
Hks waste gate
Big hks/garrett turbo
Large fuel rail
1000cc injectors
Power fc dejetro
Hasnt been tuned for injectors yet
Serge tank and external pump
Stripped interior
Trust intercooler and piping
Fibaglass front bar
Fibaglass front gaurds
Fibaglass boot with n1 lip
Brand new comp stage 5 clutch
Needs finishing but will be a fast car
Internals unknown asume stock
Heaps of spares
Contact 0411672105
Located central coast nsw
$12500
SWAP FOR CHEAPER TRACK CAR AND CASH
https://www.sau.com.au/forums/topic/374941-r32-gtr-hks-single-turbo-setup/
  • 1 month later...
Track only inport...
New yellowjack coil packs and spark plugs starts and runs but rich as. touch up tune and will make 320-350 wkws
Make some offers trade ins welcome
Is this over priced or do I just need to wait for some interest
im not expert but maybe for a non register-able track only gtr.. im looking for a track only gtr but not willing to spend that much. i have seen a few on here (already sold) for around the 7k mark which might be more like it.
http://www.skylinesaustralia.com/forums/topic/358302-r32-gtr-track-car-7000/
That's a good price for a base unit has 1500 in ecu and over 2k on the hot side let alone and also fuel system over 1k clutch band new over 600 that's y I think its worth 10k. It owes more and only had for 6 months and never even drove It
i remember this on ebay from the fiberglass front and the turbo setup, it had 2 sets of wheels on it and said it needed a tune in the post, i remember the price it was listed at but there is no point writing that up, when you picked it up was it running rough?
if so what was the problem?
what things have you done to it since purchase?
and what sort of compression does the motor have?
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
