  • Replies 182
Posted Images
back seats fold down in accord :P
but I understand the mazda is more a young persons car, its very trendy these days..we cop some flac for having an old peoples car but its a dream to drive and was owned by a grandpa churchgoer before us..the stereo was disconnected due to his religous beliefs...
Had a look at the accord, the v shape of the hole between the boot and the backseat made the hole not big enough to fit Annas makeup chair through it. The only thing on our list that did fit her stuff easily was a mazda 3 so it looks like some form of Mazda 3 will end up in the garage.
haha..yeah I wasnt actually serious man...
It was looking good unti lthe v shape! The boot was plenty big, and it was parked next to the 3 so it didnt hurt to look lol
have you looked at the mondeo hatch?? diesel is great 5.7 l/100km boot is 816 litres or thereabouts. and yes resale is not the best when new but bargain for a three year old car.
I will have a look now
v shape? What sort of accord was it?
iono haonda accord euro sedan of some sort, the port between the boot and the back seats was wider at the top than at the bottom. made it a bit useless for putting big stuff through, apart from that is was a nice car.
Whats the reliability like? What ever car we get will be doing a lot of short trips around town for Annas business. Her being able to jump in it and get where she is going everytime is really important too.
If driven hard things wear but, thats normal for anything.
Very reliable. There are a few things that go wrong that are common to the car. The issues are well known and aren't hideous to fix cost or time wise.
I use mine for work and clock plenty of kms on it without trouble.
The service message is an easy reset. Just hold the button on the washer stalk as you turn on the ignition. Then press the odo reset and your done.
I'm in the market for a new car in the sub $40k bracket, and the XR5, 3MPS, GTI and the new WRX sedan were the cars I was going to check out. Any others worth having a look at? The Megane interests me but its french and a bit out of my price range. Not sure what else is out there though. Any other suggestions?
  • 3 weeks later...
Finally found our car, Mazda 3 SP23. Anna is happy, all her make up stuff fits, It has aircon and it has a radio so she says for her purposes it is already far ahead of the GTR! lol. I dont mind it as a daily either, comfy, handles well and isnt a slug.
  • 1 year later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
