Hi Guys and Gals
I have been having brake problems for a while with my R33 GTST Series1 4 door brakes. They were sticking on and then going soft and you would have to pump them up to get any brake. Anyway it turns out that my master is shot. It sat for nearly 2 years which I think is what has caused the problem. I just seem to be having a really hard time finding a replacement master
I am happy to use anything that will work effectively. I remember reading somewhere that one of the nissan 4wd brake masters will do the job.
I was just wondering if there is anyone out there that can point me in the right direction. I dont want to just take it to the shop and say "fix it"
I do all my work on my cars and bikes myself but im just having a hard time finding a new master. Maybe its me not searching in the righ places.
Any help would be greatly appreciated.
Also hats off for everyone being so helpfull!!
I have found a wealth of usefull information before and thanks to everyone!!
https://www.sau.com.au/forums/topic/375536-r33-mater-cylinder-replacement/
Thanks for your help mate
I will have to persavere I guess
Every place I have called so far cant even find them on the computer.
Out of 5 places they have all said they dont have them in stock and not sure if they can get them. I am expecting a call back from 2 shops but the other 3 just said "sorry mate, good luck"
Thanks anyway but seems to be a little more difficult in the ACT
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
