Clarion MP3/WMA/CD High Powered 53wx4 Top of the range Head unit
Model no.DXZ766MP
This unit has all the bells and whistles, was over $700 brand new. Will suit someone looking for a top of the line quality head unit.
you can feel the quality as soon as you lift it.
This sale is for complete head unit, wiring harness and remote, all that you need.
Features:
53wx4 High Powered
Motorized sloping Face
Detachable Face
MP3 ID3 TAG
SLOPE CONSOLE
M BASS EX
24 BIT
MOSFET
4v/ 6channel Output
AUX input
Z-Enhancer sound customization
Low-pass filter
18 FM/6 AM station presets
MP3 and WMA compatible with ID3-TAG display
CD-R/RW ready
FI VFD (Fully Integrated 16-gradation full dot VF display) (256 x 64 dot)
728-variable colour illuminated keys
Screensaver
CeNET control of: DVD changer (easy), TV tuner, 6-disc CD changer
4-volt/6-channel RCA output
2-channel AUX input with level control
CeNET iPod interface compatible
full spectrum selectable LED lighting ( you can change the display to 7 different colors), 6 channel Rca output, MP3/WMA support and optional ipod connectivity.
Check this youtube clip to see some of the features of this head unit:
http://www.youtube.c...h?v=a1fA7Kf7TWI
Pick up from Taylors Lakes Melb
$200. I can post Australia wide for an extra $20
call/ sms Mob: 0422756270
post-70844-0-50151900-1314694564_thumb.jpgpost-70844-0-40420100-1314694577_thumb.jpgpost-70844-0-80972500-1314694589_thumb.jpg
post-70844-0-17854800-1314694605_thumb.jpgpost-70844-0-52408700-1314694624_thumb.jpgpost-70844-0-73427900-1314694642_thumb.jpg
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
