Hi all;
I actually thought my gearbox was rooted but thanks to an hours browsing and searching around on the forum, I found out that there are two cylinders that exist and when i went to check my car, the master was bone dry. I filled it up with brake fluid and the clutch is working better now (still not as good as before but much much better ... I tried looking for a leak but its all bone dry near the cylinder and also near the footwell. I drove for around an hour round trip and came back and the fluid was still right where i topped it up till.
My question is, should I bother replacing the master and slave cylinder or wait to see if it gets empty again? Or just go and get it bled and looked at once from a mechanic when I'm getting my gearbox oil replaced?
Thanks for your help :)
https://www.sau.com.au/forums/topic/375765-clutch-master-cylinder-empty/
When you say "footwell", did you mean inside the car? Because if you didn't then go look for brake fluid running down the inside of the firewall into the carpet and sound deadening. If you lie on your back with your head under the steering column and run your hand over the clutch pushrod (runs between the pedal and the firewall and passes through a rubber boot at the firewall) and you feel fluid, then the master has been bypassing internally and leaking out its back side. If you don't find any trace of fluid in the car, then it is probably the slave that has leaked it out. Get under the car and look for evidence around the slave. If it's been leaking there it should be fairly obvious.
If not - drive it for a week or two, check it every time you get in or out of the car, and see what happens. If the fluid goes away again, then get to a mechanic and get it fixed. Not having a clutch is a massive pain in the arse.
Yes I meant inside the car. The pushrod (if thats what its called) did have a bit of liquid at the end near the rubber seal (on the firewall end) but I'm guessing thats normal? I'll get the slave checked out while the gearbox oil is being replaced. If the fluid does not decrease after a couple of weeks, I should still get the system bled out correct?
Thanks for your input.
My R32 GTR had a leak from the clutch master cylinder that took about 1-2 weeks to notice a drop in fluid level with no obvious/noticable leaks.
Replaced the master cylinder and all good for about a year or two and then the booster stopped doing it's thing and had an intermittently hard and then soft pedal.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
