Hey guys this is my R6 for sale i was hanging on to her so my brother could buy it when he gets off his P's on the bike but it wont be for a long time and i dont want her to go to waste sitting in the shed.
I have never tracked it or thrashed it been on a few rides and commute to work and back thats about it always wait to warm it up to 60 degrees before ridding off and always been run on 98 octane or higher.
Bike is in excellent condition apart from a few scratches on the rear left cowling
Last tune very conservitive made 112hp at the rear wheel on pump 98 so about 82-4KW ATW and climbs very fast after 7,ooo rpm will quite happily power stand if your to happy with the throttle its a very quick R6 and wouldnt suggest for an inexperienced rider :)
R6
38,000kms
black tinted double bubble windscreen
Rear fender eliminator kit
Rear LED turn and brake lights
Gold Bar ends
Oggy knobs
Rear spools (frame sliders or race stand pegs)
Stealth Sprokets
Good condition chain (lubed up and cleaned every week)
K&N intake filter
Yoshimura RS-3 exhaust (stainless can)
Upgraded camshafts
Re-jetted and tuned carbies
Brand new Gel battery just fitted
Long rego
good tyres
$5200
0422646961
Picks as soon as it will let me upload them or PM or call me and i will send you some :)
https://www.sau.com.au/forums/topic/375827-yzf-r6-2001-model-for-sale-5200/
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
