hey all,
so I recently purchased a 1995 S14 series 1, with a series 2 front and rear end conversion.
perfectly running sr20det and running an s15 6 speed. however you can have the choice of a 5 or 6 speed with an adjustment to the price. (both gearboxes in perfect cond.)
currently the car is un-registered and un-roadworthy. my reason for selling is because the previous owner neglected to mention the car was a repairable write-off and hadn't had a VIV reported to vicroads. also has an EPA on the shell too.
so I handed over the cash without checking with Vicroads thinking I could just fix it and get a RWC then drive it like what I was told.
the car is dark blue - originally red. would suit someone who has a bigger budget than me or looking for a cheap s14 for track use!
COMPLETELY STOCK car.
price:
$4400 with the s14 5 speed (you will have to swap the box)
$4600 with the s15 6 speed
add $500 to cost with CST base height coilovers 8kg front 6kg rear in good cond.
will MMS pictures if requested, but its basically its a dark blue s14a with black s14 stock wheels.
contact Leigh on 0418-221-075
https://www.sau.com.au/forums/topic/375834-s14a-4500/
  • 3 weeks later...
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
