Hi guys,
Having a HOT SALE all parts going to wreckers if no interest PM offers
All items are from 99 R34 GTT
Factory Suspension $150
Stock SMIC $80
Stock dash gauges no housing $30
Pair of factory front seats $150 both or $100 each
Factory suspension parts tie rods, camber etc
More parts ive probably forgotten PM
https://www.sau.com.au/forums/topic/376035-r34-gtt-exhaust-catback-200/
Stock Auto ECU (they also work on manuals) $60
Auto Steering Wheel with no airbag module $70
Centre Console unit with the compartment, not the centre dash console $50
Auto Speedo Cluster with 107,000kms on it $100
Rb25 Auto Gearbox with 107,000kms on it $200
Catback exhaust with Nismo silencer, similar to a varex with inbuilt silencer in muffler. $250
PM any offers negotiable as we need the parts cleared from workshop.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
