Hey guys ive got up for sale my fully forged built 1000hp Rb26. Heres the list of the parts worth 22k+......
I also have my RB26 out of my R34 GTR up for sale as well for $5,000 (Motor is still currently in the car)
R34 Motor:
Aries forged pistons
Tomei Valve springs
260 tomei cams
HKS cam gears
1000hp R33 Motor:
CP Pistons
Howard Rods
Head with mild ports
282 spec cams with retainers
ARP head and main studs
Ati balancer
Custom Valves
Custom springs
Jun oil pump
Trust sump with extension
Block has been specially prepped & cleaned
Crank has been prepped & fully balanced
Motor built by Matouk Performance in sydney, does not come with turbos or manifolds etc. just rocker cover to sump
Motor made 700-750rwhp with T51R with plenty more left in it!!
For any questions pm me or msg me on 0448868384..cheers
Selling for $10,000, which is alot less than it cost to build the motor. It has been only driven around 2000kms so still new.
Sorry guys i do not have the reciepts from the build..Call 0434778285 for proof of build.
https://www.sau.com.au/forums/topic/376315-fs-r34-r33-gtr-built-motors/
pretty keen on the r34 motor, some more details please. reason for sale?
Only reason for sale is because i have 2 motors n what ever one i sell 1st i will keep the other one..but both motors are perfectly running!
How are you selling at $10k at the same time as Japanese Motor Sport trying to sell for $5.5k for the same motor????
They've also said the engine has done more KMs than what you've said
the guy i bought it off of got it built for his street gtr and decided to take it out to put it into another gtr for drag racing but decided he wanted an rb26/30 instead.
and apparently it came out of a car that was rear ended JMS says....
So what's the go here?
Jms dont owm it, it was not in a rear ended car. A kid braught it to go in a s14, didnt happn n
Braught a 34 gtr.
Its come from interstate with current owner payin much more than asking price.
If it was crashed, who cares. Do a comp test, sus it out n go pull monos in ur car!
Braught a 34 gtr.
I'm not fussed about what happened to the car... more interested in whether they can come up with the receipts to prove the rebuild or not! Which I've inquired about mid-last week and they still haven't got back to me about it...
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
hey mate,
is the engine still for sale, has it had a leak down test and can you get compression figures on all cylinders?
Also what cams is it running Brand/workshop?
where is it currently located?
cheers
Hey mate, is this "1000hp" motor still up for grabs?? If you can provide proof of build in any reliable way and can ship it to Adelaide then PM me and we'll talk some numbers k
Got cash waiting to be spent...
Cheers
  • 5 weeks later...
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
