Items located Brisbane, Runcorn
Mobile: 0415 054 949
Note: Please send PM's or SMS about parts i won't check the post that often.
Open to offers, no swaps.
Stripped a 1997 MItsubishi Magna for parts after a restoration that took a back burner once i bought my skyline.
Plenty of parts to go. See below
all parts that are sanded have been sanded wet and dry 1500grit
Koni Adjustable Shock inserts - $900
Bought brand new never used still in box, paid $1050
RDA Slotted front rotors with lucas sport pads - $300
New in box
Lovell Super low front springs - $175
Brand new
5 Speed Manual TF/ TH/ TJ Conversion - $1000
- Gear box
- Linkages
- Shifter
- Pedals
- ECU
- Clutch Cylinder/ slave and lines
- (can get the flywheel off the motor if required)
Engine Mounts plus manual gearbox mount - $80 each
TJ boot Lid - $200
- sanded and stripped for painting
TJ/ TL Tail Lights - $150
Clean no scratches all tabs in tact
Front Quarter Panels - $100 / side
TF Front Grille - $75
- sanded ready for painting
Headlights - $300/ $150 each
Side Repeters Clear (Genuine Mistubishi) - $50
Front indicators TF/ TH/ TJ - $80
Number plate lights - $30
Clean, not burnt
Set of Door Handles and barrels - $100
Ingnition Barrel and keys + remote - $100
Ignition barrel surround - $20
Remote Receiver $30
Side Mirrors - $40 each
One mirror slight damaged. - $25
Electric Mirro Switch - $50
Spare Tyre and steel rim 5 x 114.3 16" 100% Tread - $70
Spare Tyre and steel rim 5 x 114.3 16" 30% Tread - $40
Spare tyre boot brace - $25
Rubber fuel cap surround - $20
Fuel cap cover - $40
sanded
Rear bumper cap (tow bar cover) - $50
Centre console insert - $60
Air-con surround centre - $50
Interior Light in great condition no burning cracks - $35
6G72 (3.0Ltr) MAF Sensor - $100
Door Window glass - $75/ pane
stripped of tint
Seat leg plastics - $5/ set
Interior hand lock plastics -$15 each
2 x right
1 x left
Indicator Stalk - $50
Wiper stalk - $50
Washer bottle with pump - $50
Cloth Dash hole covers - $5 each
precut holes for tweeters
Tow bar - $250
2 x Tow tongue - $75 each
50mm ball
Rear crash bar - $50
Hood lining in good condition light grey - $50
Interior Plastics and visors - $Make and Offer
I have painted them with 3M Vinyl plastic paint and some have started to flake :(
I prepped with acetone but that still didn't help it stick.
post-81730-0-04037000-1315282021_thumb.jpgpost-81730-0-58072300-1315282026_thumb.jpgpost-81730-0-91042300-1315282030_thumb.jpgpost-81730-0-82824000-1315282067_thumb.jpgpost-81730-0-54965100-1315282072_thumb.jpgpost-81730-0-31175700-1315282079_thumb.jpgpost-81730-0-76761200-1315282084_thumb.jpgpost-81730-0-86725400-1315282091_thumb.jpgpost-81730-0-39408400-1315282097_thumb.jpgpost-81730-0-03902500-1315282105_thumb.jpgpost-81730-0-02161100-1315282503_thumb.jpgpost-81730-0-45589900-1315282522_thumb.jpgpost-81730-0-61836300-1315282532_thumb.jpgpost-81730-0-32759500-1315282543_thumb.jpgpost-81730-0-04849000-1315282552_thumb.jpgpost-81730-0-61863400-1315282560_thumb.jpgpost-81730-0-41326800-1315282569_thumb.jpgpost-81730-0-44184600-1315282579_thumb.jpgpost-81730-0-47039200-1315282640_thumb.jpgpost-81730-0-95628500-1315282650_thumb.jpg
post-81730-0-06863200-1315282660_thumb.jpgpost-81730-0-92857900-1315282677_thumb.jpgpost-81730-0-51569000-1315282684_thumb.jpg
post-81730-0-04862100-1315282895_thumb.jpgpost-81730-0-69775100-1315282903_thumb.jpgpost-81730-0-75854700-1315282871_thumb.jpgpost-81730-0-04877800-1315282850_thumb.jpgpost-81730-0-33308400-1315282862_thumb.jpgpost-81730-0-27901800-1315282807_thumb.jpgpost-81730-0-09458600-1315282819_thumb.jpgpost-81730-0-07515800-1315282829_thumb.jpgpost-81730-0-21836800-1315282839_thumb.jpgpost-81730-0-65131900-1315282720_thumb.jpgpost-81730-0-35837200-1315282729_thumb.jpgpost-81730-0-24709700-1315282739_thumb.jpgpost-81730-0-20938200-1315282748_thumb.jpgpost-81730-0-60579200-1315282759_thumb.jpgpost-81730-0-85352900-1315282768_thumb.jpgpost-81730-0-63836800-1315282777_thumb.jpgpost-81730-0-73890300-1315282785_thumb.jpgpost-81730-0-43182600-1315282798_thumb.jpgpost-81730-0-82411700-1315282692_thumb.jpgpost-81730-0-59817800-1315282700_thumb.jpgpost-81730-0-84924200-1315282710_thumb.jpg
Edited by PickleNick
https://www.sau.com.au/forums/topic/376384-magna-1996-spare-parts-tf-tj-th-tl/
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
