I'm so pumped for this, I'm even thinking of buying some rear tyres specifically for it.
I haven't drag raced a car for 25 yrs, and back then it was not what you could call legal, memories of the Foreshore at Botany at 3am on a Saturday morning in my LJ GTR.
Ah how times have changed, mostly for the better.
This is going to be sweet, I'm gonna do a heap of runs and relive my slightly naughty youth.
Do wish I still had the LJ though.
https://www.sau.com.au/forums/topic/376518-drags-at-the-creek-with-sau/
Red, 202 with triples, hot wire rims, I was as fast as and handled like a dream for back then and what it was, carb was changed to a 350 holley at the end as the triples were a bother to keep tuned.
Sold long ago unfortunately.
I said to the missus at the Muscle Car Masters that I should buy another one, she just looked at me and said sell your R33 and use that money to buy one, I shrugged and said maybe knowing full well that the 50 odd thousand that I've spent on it would equate to about 15k at resale, and hence no where near enough money.
I do need to win LOTTO, or have a sneaky SUGAR MOMMY.
Who am I kidding, like all women my missus is psychic and would know and kill me dead.
I have find memories of Foreshore Rd ;) Mates used to have a wine coloured HG GTS that used to frequent there years ago.
And yes, I am also pumped for next Saturday week as I haven't been to the drags in a while...but not quite 25 years :D
the lj is my favorite 'ozzy car'
my dad had a 186 in his hq, it started with a 350 holley then he put triple su's on it ( i still have the 350 holley that was on it outside in my shed.)
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
