Guest RedLineGTR
The problem with oils like that is that they are a mix/blend of what i dunno?? Different doses of specific lubricants, elements, chemicals etc...It’s more of a semi-synthetic and for 10-20bucks you can get a oil that is more based on a full sythetic oil such as mobil 1 or motul etc. It’s usually worth the money especially in a turbo based car which experiences high temperatures. My 2 cents
Yeah, I've used it a coupe of times. Not too impressed, I feel my fuel economy etc is a little less. Before I was using valvolvine 10-40 semi synth something, I felt that was better. But this time Im going to try a full synth, see how that goes.
nah.. its fine.. changing the oil regularly is more important than what you use as long as its not too shithouse.
I don't think they're as high as 85% mineral.. they're rated for turbo engines. It wouldn't say it on the bottle unless it was safe to do so. In fact there is probably **** all difference i reckon, other than the name and marketing associated with the expensive stuff.. but of course I'm not a chemist so couldn't determine that empirically..
Been using it for 18 months or so in mine, no problems. Doesn't seem to break down and go black that quickly, so i assume its doing its job reasonably well.
Makes perfect sense RedLineGTR. However, your better off getting say, a bottle of Shell Helix Synthetic ($45) and keeping that for 10,000ks than say, Castrol GTX Magnatec ($25) and keeping that for 5,000ks.
You dont need to buy stuff like RP/Redline for good oils. Mobil 1, Castrol R, Shell Helix Ultra etc are well suited to a daily driven GTST and dont cost the earth. Redline/RP are overpriced IMO and only is worth it if u drive ur car hard on a regular basis.
I dont want to sound like an arse, but you guys dont know what you are talking about!
Semi synthetics are not made up of a mix of synthetic and mineral, in most cases they are a mineral base thats been hydrocracked to perform like a synthetic. Base oils come in 4 different groups 1, 2, 3, and 4
Group 1 = Basic oils like chain lubes.
Group 2 = Most Oils like engine oil, gear oil, hydraulic oil, industrial oils
Group 3 = Highly Refined mineral oil (Semi Synthetics) High performance Lubricants, Engine oil, gear oils and other high performance lubes
Group 4 = Polyalpholefins or POA (Fully Synthetic) (Man Made) Extreemly high performance lubes for high temperatures or extended drain intervalls
Group 3 oils are sometimes listed as synthetic because the chemical structure of the base has been changed by man so therefore its man made and hence called synthetic.
I hope i haven't up set to many people but i had to explain how it works or im going to go nuts reading some of these posts.
Any Semi synthetic or fully synthetic is going to perform well above what you guys are going to put it through, so long as you change it at regular intervalls.
kingscorp, some of your information is kinda wrong. So dont say we are completely wrong! Hehe Im not going to retype out the info so just go here for a real rundown of the API Grp listings.
Grp I- solvent refined petroleum base stock.
Grp II- hydrotreated petroleum base stock. More refined, with less gunk in it. More stable, and usually with a higher viscosity index. Chevron and pennzoil oils use nothing but this group in their oils.
Grp III- "hydrocracked" or severely hydrofinished base stock. Castrol won the right for oil blenders to call this group "synthetic". Most OTC synthetics are made from this base. I think they use the same process to make it as GII, but take it a step further.
Grp IV PAO base stock. Chemically produced from ethelene gas. True synthetic oil, and primary basestock used in mobil, amsoil and most top tier synthetics. Much more stable and has higher VI index than GIII. Can handle more extreme temps.
Grp V ester base stock. used in most synthetic oils for miscibility, and is primary base used in redline and a few others. Extreme natural detergency and cleaning ability. Strong attraction to metal. Can withstand more extreme temps than PAO.
FYI, a classic semisynth like Castrol Magnatec, Valvoline Durablend IS a mix of a Grp I and III oil altho the percentages can vary. It can be only 1 drop of synth per bottle and they can label it semi synthetic.
Castrol GTX/2/3 etc are Grp 1 oils, and arent just chain lubes. Grp 2 oils are oils like Penzzoil Purebase, Group 3 includes Shell Helix Ultra, the cheaper Castrol R 5W-30. Grp 4 is Mobil 1 Supersyn, Castrol R 0W-40 etc and Grp 5 is Motul 300V, Redline etc.
If you wanna know more about oils, go to this excellent resource;
www.bobistheoilguy.com
Guest Moses
What you have said is pretty much the same as I described. But if Shell found out that you reckon that their top tier product Helix Ultra was a group 3 product they wouldn'e be happy.
Oil companys use the different base stocks just in different applications. To say that 1 particular brand only uses one type of base stock is incorrect. I work for one of the major oil companies and we use all of the different Bases in different percentages in many different products.
Your last comment is completly wrong
(note this post is from Kingscorp note Moses, I was on Moses computer)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
