Twin turbo kit from rb26 with manifold modified to suit rb20/25, comes with turbos, manifolds, lines, some piping, dump pipes, rb26 afms $1100ono
RB25 hiflow injectors, good condition $500ono
Fibreglass R33 GTR bar, average condition $50
R33 Bonnet lip $120ono
SR20 Auto trans $10
RB25 Auto trans out of s2 and is shifted $offers
R33 Non turbo brakes $offers
Pics will be up soon
Located in Enfield, SA
PM or contact me on 0406400736
Thanks
Gary
https://www.sau.com.au/forums/topic/376811-rb2025-tt-kit-rb25-hiflow-injectors/
i reckon i was given extra parts when i bought it, i think you would run a aftermarket computer or your afm and y piece into the turbos
Edited by GARY_032
