Topic Title: Kidders Kruise V2
Date: 9th of October(Sunday)
Time: 9am Meet, 9:30am Departure
Meet Point: BP Kewdale (Abernethy Road)
Map: Toodyay Throttle
http://www.westcoastcruisers.com.au/Forums/topic/1677-kidders-kruise-v2/
Running this again due to the large success of the previous one.
Usual cruise rules apply, no burnouts / cranking stereos at meet points. Whatever else you do between legs is none of my business ;)
We will be having lunch at Toodyay which is the last meet point.
Can't wait!!
No, I won't be in my bubble...
Edited by dan_the_man
https://www.sau.com.au/forums/topic/376891-kidders-kruise-v2/
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
