Guys my front bar is going to be replaced in 2 weeks so the old one needs to be sold.
Its a original style GTR front bar with the 2 air vents, front bar extension and original grill. The colour is silver. The bar is in reasonable condition but a respray to any colour will make it immac. It also comes with the orange indicators to suit your application.
The price is $499 neg. But remember its GTR front bar with GTR Big Grill. It is sold to the guy who pm's me with a reasonable offer. It suits any GTST series 1 or 2.
The front bar is in melbourne people so i would prefer melbourne buyers.
Cheers
Amit
https://www.sau.com.au/forums/topic/37754-r33-gtr-front-bargrill-suit-gtst/
is the bar silver?Is it fiber glass or plastic? Im looking for a front bar for my car.. PM me so we can arrange a time to see it.. 499 is too much, u can pick one up from jeet speed for abt 380.. neways we see how we go..
cheers,
rob
well its fibreglass. well im selling the front bar with the grill and indicators. I doubt jetspeed would provide you all that for this price.
cheers,
rob
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
