Hey Everyone!
Im after a bit of advice or opinions, all welcome.
Ok i have a problem with my car R33 skyline GTST. s2.
When i take off in 1st or even when im in 2nd or third just after i press down a touch on the accelerator it dies and then kicks back in. So if i gently ease on the accelerator around 3grand or so the car will die and if i dont move my foot it will kick back in a few seconds.Doesnt happen everytime but 80percent of the time. seems to be around the bottom end of the rev range. it will push through if i put foot to floor but is sluggish.sometimes it will spit and splatter around,if i put the foot down a bit it will push through it and come better,somedays it will go a little better then others. It wasnt as bad and seems to of gotten alot worse. I will post a video when i can get a chance to record it.
I hav new plugs and splitfire coil packs( 6 months old). AFM has been clean and working fine,fuel pump is 6months old. TPS has been checked and is fine. Its been to a mechanic and we both had a look at it, he did a fuel pressure test and pump was fine,it didnt effect the pressure when the car carries on. He has had a look over everything but said it could be a number of things its a matter of eliminating them one by one. Injectors are my next check. May have to purchase new ones as it is 350 to be clean and tested.
Mods are pretty basic. exhaust, front mount, greddy plenum,splitfire coilpacks, profec spec B II boost controller (10psi) turned off though so should be running stock,walbro pump..
It started a few weeks ago when i had a flat spot at the top end of my rev range and i did some research and gapping plugs to 0.8 seems to fix it. After pulling my plugs out and gapping them i had this slight issue that got worse and worse so i regapped back, still had this problem so i got new plugs back to 1.1iridiums that i had at the beginning. problems still there. mechanic reckons it was a coincidence and is not a plug issue..
Help and opinions much appreciated.
https://www.sau.com.au/forums/topic/377980-help-and-opinions/
I don't spose there is water in your fuel tank by any chance? Sometimes it is hard to pinpoint electrical issues, especially when it runs fine sometimes and crap others. Find someone with a skyline that will let you swap parts over to see what is wrong. Put all his good parts on and then swap yours back one at a time till it plays up and there's your culprit.
if it revs in neutral but dies/struggles under load it is a fuelling issue.
It won't be injectors it will most likely be AFM which i know you said you had changed but i would swap with someone for 10 min to test it. If this is not a constant thing but an intermittent problem i would look at wiring for the afm, however if its just every now and then specifically when you put your foot on the accelerator a bit you are looking for a dud wire somewhere as thats when the motor kicks a bit and shakes things up if you have a pod on there and not the standard airbox bolted to the car.
Give us a bit more info and we may give some more clues. ECU supplying the wrong fuel can be from vacum leaks meaning afm is inaccurate, it could be when going from closed loop to map etc etc.
I may able to borrow a mates skyline and swap AFM etc.. ill post a video in a few hours.. I did the re-wiring for the greddy plenum 6 months ago(aac vlave iac),TPS wires extended. it may hav become loose or something.... The AFM was cleaned when the plenum was done and iv checked the afm and its squeeky clean.. ill just hav to spend a day checking everything i guess.. thanks guys
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
