Stock R33 GTST Series 1 RB25DET 370cc Injectors - a full set of 6.
(Good Condition) was removed due to upgrade.
Car was stock at as a rock and removed @ 96,000kms
$120 for the set. Pick up from Taylorslakes (melbourne)
Can post Australia wide for an extra $10.
Call / sms Mob: 0422756270 if interested.
Edited by G4orce
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
