WRECKING BOTH R32 and R33's, post in here or PM me what you're after. a few specific parts:
TRUST GREDDY gear knob: $50
R33:
R33 HKS SuperDragger Exhaust: $450
R33 GTR Rear Strut brace (fits all R33's): $90
R33 Brakes, uprights and hubs (complete) - $800
R33 front Upper control arms - $70ea
R33 Upper control arms/Traction arms - $50ea
R32
R32 GTR grill: $140
Whiteline 22mm Solid Rear Sway Bar (+links): $150
Front Sway Bar - $40ea
Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
Front Camber Arms - $40ea -- PICS
Rear Traction arms - $35ea -- PICS PICS
Rear Camber arms - $35ea -- PICS
Rear Hub Uprights - $100ea -- PICS PICS
Rear Complete Uprights - $70ea
Rear Subframe - $100
Rear Toe Rods (non-hicas) - $40ea -- PICS
Doors, 2door (coupe), silver - $70ea
Drive-shafts - $50ea
Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
located near mitcham in SA, will post anywhere in Aus
https://www.sau.com.au/forums/topic/378717-r-3-3-r-3-2-p-a-r-t-s/
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
