Sad sale of my Toy that I havent been able to use as yet.
300kms since engine rebuild; will run a cple hundred more and have the Ecu tuned.
Spent in excess of $25,000 using mostly new parts throughout.
Regretful sale due to Divorce asset split arangement. No tyre kickers, No test drives without deposit, No low ballers
Most items below are New
Forgotten plenty of other parts - all work carried out by Boostworx
Sold as Track/Race car without registration
Previously registered in VIC, #SQD-128
$15,000 is the sale price - or best offer
May 1993 Nissan Skyline GTs-T Rwd 4door grey sedan with Blitz fibreglass bonnet & GTR rear wing
RB30 VL-turbo 5speed manual rebuilt gearbox with single button clutch
GTR RB26DETT 300-km old fresh rebuilt engine with freshly rebuilt steel wheel turbos
Intake & Exhaust
600x400x100mm FMIC kit, stock BOV setup
Greddy-copy hardpipe intake kit, twin pod filters
Z32 AirFlow meters
Twin HKS split dump pipes
OBX tuned-length manifolds
OBX flex front pipe into 3" resonator decat pipe
5Zigen 3" turbo back exhaust
Fuel System
GTR intank fuel pump
550cc Siemen Denso Injectors, new O-rings, seals
Fuel pressure regulator, adjustable
Walbro 305LPH external fuel pump
4 litre fuel surge tank, 5m braided lines, speedflow fittings
Rebuilt Engine
ASI 52mm dual core alloy radiator, Blitz cap
Yellow Jacket coil packs
Greddy oil filter
Ryco fuel filter
Champion Gold sparkplugs
JC-Project radiator silicone pipes
ATI 600hp Harmonic balancer damper & pulley kit
N1 water pump
HKS oil pump
Tomei oil baffle sump plate kit
Tomei oil gallery orifice
Turbotech manual boost controller
1L Oil catch can
Oil filter relocation kit with speeflow fittings
Oil cooler finned 30-row unit, speedflow fittings
ARP Head stud kit
Cometic Street Pro 87mm MLS head gasket
Nissan full gasket set
HKS step-2 valve springs
R34 Greddy N1 Street Special camshafts, R34 CAS
Ported & Flowed headwork
Greddy timing belt
Precision adjustable intake & exhaust cam gears
Drive key, tensioner & idler bearing kit
87mm CP Piston kit - full block tidyup
Power–FC & Hand Controller
Suspension, Brakes & Wheels
Greddy engine strut tower brace & custom boot strut brace
High-Temp racing brake fluid
Braided front & rear brake lines
Wilwood 4-piston Superlight front brake calipers
Brembo 324mm drilled discs, bracket adapter kit
Stagea rear brake calipers & discs
Coilover adjustable suspension
Nismo front tension rod link set
17 x 8 inch mags
235/45/17 Kuhmo KU36 semi-slick tyres
Interior
Autometre boost gauge
Saas gear knob
Saas steering wheel & boss kit, spare R34 steering wheel
Bride low drivers seat rail
Bride drivers bucket race seat
Bride low passengers seat rail
R32 passenger seat
4-point harnesses
4-point Roll cage, bolt in
M's turbo timer
Apexi Power Metre gauge
EBCR exhaust gas temperature gauge
AEM wideband sensor gauge kit
Short shifter
Tomei 300kmph Dash
Apexi Multichecker display unit
+ more..........................
I REALLY dont want to; trust me on that.
My plans were to track the car 3x a year for the next 5 or so years while I go through University studies.
Have to sell the House in regards to the divorce, on the disability pension & I cant meet the repayments currently so the Bank is getting antsy on me.
If someone wants the track car more than I do then so be it, they'll be getting a "half price" bargain, but I wont be giving it away. If the contract on the house sale finally goes through (been under contract for 1/3 of the year now) then I wont sell this track car, but the house buyers are stalling, stalling & its put me in a bit of a financial hole so I must keep my options open.
Engine running-in is now complete
Drives like a dream, and has massive response for 8psi :)
Will be tuned once Ive sold the house & moved out (by years end).
Wont be selling if the Stagea sells first.
see sig for link.
Thanks for the comments, Im keen to track this as often as possible during my University holidays
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
