I can see how the overfueling would be caused by having no bov if you are still running the standard ecu. However that would only cause an issue at low throttle/idle/decel, as that is when the ecu would be expecting the bov to be leaking air. If you have an issue throughout the whole fuel map (ie. accelerating), I think that will be because of the aftermarket plenum and turbo. The stock ecu runs rich as all hell when you start messing with the intake. I bet if you restored the factory bov setup, you would still have overfueling issues.
Either way, both those issues can be solved by a tune. I think your next step should be to get a tune-able ecu installed and get it on the dyno, your tuner will quickly be able to identify if the problem is just in your maps or if you have an underlying issue.
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6056581
hanaldo... my problem is only on idle/decel so its possible but im going to wait till i get my vipec and tune around it.yes this is my next step to put a tunable ecu on it and i have come to realise this could/probably will help solve my issue and seeing as though i am planning on doing it anyway ill just wait till then. i see how the bov/bypass valve can cause it as well but like i said before i think ill just wait for the computer now afm is standard and i have tried another and no difference, the vipec has a map sensor so i wont have any reversions problems or any other possible afm related issues.
craved... injectors and fpr are standard for the time being i have some 740's to put in ad i have a surge tank with 044 i just need to hook up for when i get the ecu and im planning on keeping the fuel pressure standard as i doubt ill need higher at the power level im aiming for...
thanks for the replies guys
supporting mods are front mount intercooler and exhaust and thats bout it at the moment
Edited by PaulosECR33
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6058002
Is this what it does??
I don't think it's the bov, my money is on the cold idle control valve. Not the same as the AAC valve just by the way, but it's near it. The cold idle control valve is much like a thermostat, it's a piece of thin coiled wire that expands when it gets hot to block the vacuum line. It's very easy to break, and if it get's stuck open then the vacuum line will be constantly open and act like a vacuum leak when the car is hot.
The valve is on a vacuum line coming off the AAC, so try blocking these lines to see if it changes anything. Also try running the car with the AFM unplugged. Try things to change it's symptoms so you can narrow it down.
my r33 seems to have unstable idle when after warmup.
where exactly is the thin wire coil? is the vac line coming out from the bottom of the AAC unit to the air regulator?
thanks
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6068091
that is what i blocked off to stop the hunting so me thinks this is it
once i got round to it i put afm in cooler piping just before throttle body and is fixed.. waiting for vipec, not driving as afm is duct taped to throttle body and lovely cut & shut extension wiring for afm atm thanks for ur help peeps. thumbsup.gif
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6069417
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
