hi guys,
just wanted to know what is a good tyre to use and the reasonable price for them?
I currently have bridgestone potenza re50a 245/45/18 but it is due for a change. I have noticed that the rear wheels doesn't grip so well from a hard takeoff.
I've read some reviews on other tyres but not sure
how reliable they are so I am seeking some personal experiences.
if you could post the brand, quality and price I would really appreciate it.
I also heard that new tyres our from bridgestone re002 any users??
https://www.sau.com.au/forums/topic/379242-new-tyres/
How about something a little left of field?. Nitto Invo made by Toyo tyre:
http://www.nittotire.com/Tire/invo
I'll be replacing my Yokohama V103 with these because all reviews would indicate they are better at half the cost.
Contact Ali at Taleb tyres (Forum sponsor): http://www.skylinesa...er-taleb-tyres/
Edited by mosoto
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6046580
Im using Maxis Vectra 4, 245/35 20s. They grip well the rears are a little worn as they where on the front for a month or 2 b4 i had the old rears replaced, they grip well they do break traction in the wet if you go hard but what set of rubber doesnt.
Edited by T4NK
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6046798
http://www.tyrereviews.co.uk/Tyre/
guys, try this site for some decent reviews for tyres. avoid the cheap stuff...
I had Yokohama Advan Sports, and they stick like glue. However, they are really pricey. So, i got Kumo KU31s this time around, and they are not tooo bad.
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6046856
I have Khumo KU19s on the rear of mine. I can't really compare them to anything except the front tyres, I bought them because they were $185 per tyre, plus fitting. which was cheaper than most of the 'no-name' brands. They have been good so far, but they have only done about 1000km, far too soon to give a good opinion.
Unlike the tyres on the front, which are noisy!! I think they are the original Japan tyres (which I know shouldn't be used, but they where on it when I brought the car and it passed a roadworthy!), they are Yokohama dB euro. Either it's noisy tyres, or I have a bad wheel bearing, but the noise seems to go away over about 50km/h, which doesn't usually indicate a bearing!..
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6047646
Anyone on the goldcoast or brissy have a road worthy set of 19" at all? I have tyres coming in but 4 weeks away and need some to clear my defect. They were supposed to be here already but some delay in customs....
If anyone can help please PM me or SMS <removed>- need them asap.
Or im looking to but some 18x9 with 245s on them i can track with, let me know if you have anything.
Cheers
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6047809
I have crappy bridgestone's on the car still from when I bought it about a week ago. They have f'all tread left but still seem to do the job.
Looking at the P7 by Pirelli or the KU31s by Kumho. Had Kumhos in the past and have been great to me. Bob At tyrepower Newcastle looks after me every time.
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6050484
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
