Hi all,
Looking to give away my collection of car magazines to a like minded individual.
Mostly Zoom & HPI with a small collection of Hot4s, Speed, Tarmac & Motor thrown in. Age of the mags are 90's to mid 2000's - had a on going subscription to Zoom and HPI.
Note if there is no takers by Friday they'll be recycled :O:yucky::(
If you have any ideas if of how to put the to good use let me know.
PM for details
Cheers
Tim
https://www.sau.com.au/forums/topic/379489-free-to-a-good-home/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
