Quick rundown.
I did my clutch to get ready for my 35r turbo setup, put in my 1000cc injectors and made a decent base map to get me started. then, i got on to all the goodies on the exhaust side of the engine. I buttoned everything up....... and no start. cranked and cranked and it turned over but no start. The next day I got ready to attemp to diagnose it. cranked and fired up real fast. it ran all day. I started to tune it got the dump pipe put on the wastegate. and called it a day. the next morning went to go do more tuning. and no start. just like the first day. it will crank and crank and crank not even a pop. I do have power to the coilpacks, the plugs look good the top of the pistons look dry...any and all ideas welcome.
it ran very strong when it was even running 10.3:1 afrs under boost. thanks in advance, John
https://www.sau.com.au/forums/topic/379565-intermittant-no-start/
I am running an AEM series 2 standalone. I just havnt been able to fine tune the start.
what initial injector pulse and cranking injector pulse would you run with deatshwerks 1000cc injectors???
I think it is an electrical issue with no power getting to the injectors... time will tell.
Thank you
I have ignition at tdc for start up and i Saw it at the plug. with the coil packs un plugged and the 1 plug out i looked in the cylinder while cranking. no fuel spray at all.I have 12 volts at the injector pigtail with the key on engine off.
what controlls the pulse? ground??
