Yes. The difference between a $1k centre and a $2k centre is not worth it when the whole exercise will cost double that anyway.
An excellent question. Both answers are correct. I think the reality is that any Neo you get from Japan may well be the same as any other engine that has spent too many years in Japan. That being the problem of low to zero maintenance and oil changes, etc etc. So any Neo you get from Japan should be considered to be sufficiently risky to warrant planning to pull it apart and rebuild it anyway. That's a significant extra $3.5k impost on top of doing the same to your S2 engine, and the question has to be asked, would you rather have the (somewhat small) betterness of the Neo for $3.5k, or would you rather spend up to $3.5k on even better betternesses for the S2? New ECU? Better triggering? Better oil pump, sump, cam covers, etc?
Hi guys, I have a ECR33 97 model. Engine has a cracked ring land. Would it better to rebuild the series 2, or buy a second hand AWD 25det Neo from Japan from ~$3500 tidy it up a bit with new seals and so forth and use that? I'm leaning more towards the NEO option but understandably they're very old engines too now, so could be just buying problems. Cheers.
Tell us about the on ramp?
I just had a little drive and monitored oil pressure with my MHD sensor and plugin. Its perfectly within range. ~40psi at idle, ~75-80psi just cruising and ~90-95psi at WOT.
