Hi Everyone,
Had this Genuine NISMO rear bar for my widebody R34 but it would be a waste to make it fit.
It is in pretty good condition, marks and scratches all over it. Some paint cracking. Bit of a stain but easily cleaned off.
Pictured best I can.
Should be fine with a quick touch up.
There is also a crack in the corner which someone repaired quite oddly from behind. Pictured below.
I'm asking for $650
Can be posted Australia wide. You just pay for postage, possibly through e-go.com.au or transdirect.com.au
You organise it, i'll have it wrapped in bubble wrap.
Will be picked up fro 4157 Brisbane QLD
Pictures below, any other question, just ask.
Mock fit up to my wide body:
  • Replies 69
Posting on behalf of a mate.
According to the link pics & serial number its the same bar.
His offer $280 plus freight.
http://www.ebay.com.au/itm/170704825939?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_1413
  • 3 weeks later...
Everyone knows you have bought it for that price range thats prob why you are receiving offers in that price range...
oh snapt
poor guy is trying to make a living...let him go
It was purchased at a bit more than advertised price.
Does not mean I have to sell at that price.
Selling as it does not fit my car.
Happy to hear more offers.
It is worth what it's worth.
Find me a genuine nismo r34 rear bar and I'll be happy to look into it and possibly price match.
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
