Rb25 series 2 coilpacks full set with rail $150
rb20 starter motor $60
R32 Handbrake setup with lines $60
Stock r32 front camber arms$50
Black good condition momo steering wheel $120
R32 stock turbo $150
R32 bash plate really good quality $200
CEFIRO cat back exhaust have front pipe also $200
R32 stock black spoiler has reverse light $50
Rb coil pack covrr black $25
Greddy fmic for rb20 r32 $300
Stock r32 side mount cooler $15
Ford mesh rims x2 15's 5x114.3 silver & tyres $60
Rb25 shifter $40
Rb25 cross over pipe blocked bov $30
Rb20 bare engine blown $50
R32 blck front guards pair $250 been liped
guard roller blue $200
Harness red momo $50 works 100%
Hoppers crossing
pixs soon or sms me 0430078630 lots on my phone . will deliver anywhere in aus.
https://www.sau.com.au/forums/topic/380882-skyline-parts/
more parts added:
twin pipes/drift pipes brand new never used they have bolt in silences. $150
surge fuel tank brand new never used has bottom plate,bracket on the plate for a external fuel pump, and a 2l tank on the plate aswell.very good quality$250
oz racing wheels 2x 17x9+30 rims good dish, good tyres. $550
red jack its not really low but low over 1000kg capacity .$150
https://www.sau.com.au/forums/topic/380882-skyline-parts/#findComment-6073677
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
